Yann DIRSON wrote:
> Hi all,
> I am using 2.0b3, and I'm hit, like others before me, by the removal of
> "contact_groups" from the hostgroup directive. Note that
> docs/notifications.html in 2.0b3 still mentions this feature.
> The changelog mentions that this feature was removed to make things
> consistent with service notifications, but does not explain why this
> feature was considered useless.
> My problem is, I have many hostgroups, used to activate specific checks,
> most notably per-organisational-unit hostgroups (not all services are
> deployed in all OUs), but also per-OS, per-type (server, network
> equipment, etc.). The contacts for those machines are not the same,
> depending on the hostgroup. Specifying a contact_group for the hostgroup
> seems the obvious way to declare this.
> If I want to declare such a setup using only host definitions, I can't see
> how to avoid declaring host templates for each combination of
> ou/os/type/whatever: this clearly does not scale.
> Is there a clean way to get the equivalent functionality, or should this
> feature simply reintroduced in 2.0 ?
Make heavy use of templates. That's what makes nagios scale in the first
place, and consolidating the scaling part to one area makes it easier
for first-time users. It's also cleaner code-wise, because things can be
generalized and doesn't have to have so many exceptions (coders hate
exceptions).
> Another related issue, for which I did not find a solution, is how to send
> service notifications to contacts defined on a per-host basis (the admins
> for the machines, presumably located in the same part of the building, or
> in direct contact to the users). Maybe this could be done by adding a new
> notify_host_contacts flag to services (and servicegroups), that would
> cause service notifications to be sent to host contacts, and possibly a
> per-host services_contact_groups, if there is a need for those contacts to
> be different from the host contacts (although I have no use for the latter
> myself at the moment).
I've thought about implementing this myself for quite some time,
although I had the idea that contacts should be inherited from the host
if none were set in either the service-template or in the service object
definition itself. Your way is cleaner, since you provide a way to both
inherit and name contactgroups explicitly.
OP5 AB www.op5.se
Lead Developer
