We have this configuration:
Red Hat Enterprise Linux Server release 5.3; 32 bit; VMWare Image of NagiosXI; No special configurations.Using Mozilla Firefox3.6.8.
We are trying to use WebTransaction Plugin following the testcases from the manual How to monitor web sites with XI, but after creating a new valid account and replacing the values for USER and PASS; none test past succesfully. Below I pasted both files used: config.xml and testdata.xml.
http://library.nagios.com/library/produ ... -nagios-xi
orey_testdata.xml
<testcases repeat="1">
<testvar varname="USER">angel.quintero@cwpanama.com</testvar>
<testvar varname="PASS">password</testvar>
<case
id="1"
description1="Login page"
url="https://members.oreilly.com/account/login"
parseresponse='_authentication_token" type="hidden" value="|"|escape'
verifypositive="Sign in"
<case
id="2"
description1="Sign in"
method="post"
postbody="email=${USER}&password=${PASS}&_authentication_token={PARSEDRESULT}"
verifypositive="https://members.oreilly.com/account/benefits"
parseresponse="found at |;"
<case
id="3"
description1="Members page"
url="{PARSEDRESULT}"
verifypositive="view or edit your account information"
<case
id="4"
description1="Book price"
url="http://oreilly.com/catalog/9781593271794/"
verifypositive="59.95"
<case
id="5"
description1="Book added to cart"
url="https://epoch.oreilly.com/shop/cart.orm ... 71794.BOOK"
verifypositive="Nagios, 2Ed"
<case
id="6"
description1="Book still in cart"
url="https://epoch.oreilly.com/shop/cart.orm"
verifynegative="Backorder"
<case
id="7"
description1="Logout"
url="https://members.oreilly.com/account/logout"
verifypositive="http://oreilly.com/"
<case
id="8"
description1="Main page"
verifypositive="News & Commentary"
</testcases>
more orey_config.xml
<testcasefile>orey_testdata.xml</testcasefile>
<useragent>User-Agent Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.8) Gecko/20100722 Firef
ox/3.6.8</useragent>
<timeout>20</timeout>
<globaltimeout>40</globaltimeout>
################################ OUTPUT ######################33
[nagios@nagioscwp webinject]$ ./webinject.pl -c orey_config.xml
Starting WebInject Engine...
Test: orey_testdata.xml - 1
Login page
Verify : "Sign in"
[nagios@nagioscwp webinject]$ vi orey_testdata.xml
Login page
Verify : "Sign in"
Failed Positive Verification
Failed - No Response
Use of uninitialized value in substitution (s///) at ./webinject.pl line 1161.
TEST CASE FAILED
Response Time = 196.038 sec
Use of uninitialized value in substitution (s///) at ./webinject.pl line 1148.
Test: orey_testdata.xml - 2
Sign in
Verify : "https://members.oreilly.com/account/benefits"
TEST CASE FAILED
Response Time = 200.539 sec
Test: orey_testdata.xml - 3
Members page
Verify : "view or edit your account information"
Use of uninitialized value in pattern match (m//) at /usr/lib/perl5/site_perl/5.8.8/HTTP/Cookies.pm line
TEST CASE FAILED
Response Time = 0 sec
Test: orey_testdata.xml - 4
Book price
Verify : "59.95"
TEST CASE FAILED
Response Time = 20.605 sec
Test: orey_testdata.xml - 5
Book added to cart
Re: monitor web sites with XI
- Are you sure your XI server can access O'Reilly's web site?
- Do you have all of the necessary Perl libraries installed?
- That example is known not to work if you have an ampersand (&) in your password.
Ok Thanks tony.
So I will dismiss the internet test.
Basically I am using that example as template for monitoring our Intranet sites that requires user login checks. We have several services already monitored, but I tried adjusting the example for my needs:
Is necessary to install more modules in XI? Where is the list of modules to install in XI.
What I do not realize is the message: Use of uninitialized value in substitution (s///) at ./webinject.pl line 1161.
[root@nagioscwp webinject]# more unicorn_testdata.xml
<testvar varname="USER">consulta</testvar>
<testvar varname="PASS">consulta23</testvar>
<case
id="1"
url="http://10.251.0.201/webclient/"
parseresponse='OLDVALUE_LOGINUSUARIO" type="hidden" value="|"|escape'
verifypositive="Usuario"
<case
id="2"
method="post"
postbody="LOGINUSUARIO=${USER}&LOGINPASSWORD=${PASS}&OLDVALUE_LOGINUSUARIO={PARSEDRESULT}"
verifypositive="VOD"
<case
id="3"
</testcases>
[root@nagioscwp webinject]# ./webinject.pl -c unicorn_config.xml
Test: unicorn_testdata.xml - 1
Login page
Verify : "Usuario"
Passed HTTP Response Code Verification (not in error range)
TEST CASE FAILED
Response Time = 0.051 sec
Test: unicorn_testdata.xml - 2
Sign in
Verify : "VOD"
TEST CASE FAILED
Response Time = 0.004 sec
Test: unicorn_testdata.xml - 3
Members page
Verify : "VOD"
Use of uninitialized value in pattern match (m//) at /usr/lib/perl5/site_perl/5.8.8/HTTP/Cookies.pm line 44.
TEST CASE FAILED
Start Time: Thu Mar 31 16:15:54 2011
<case
id="1"
<case
id="2"
method="post"
<case
id="3"
</testcases>
Login page
Verify : "Usuario"
TEST CASE FAILED
Sign in
Verify : "VOD"
TEST CASE FAILED
Members page
Verify : "VOD"
TEST CASE FAILED
To be honest, I need HELP
Has anybody tested webinject with WRONG password?
it keeps me displaying TEST CASE PASSED and this is really annoying.....
Sign in
Verify Negative: "TV"
Passed Negative Verification
TEST CASE PASSED
Response Time = 0.076 sec
*****************************************************************************EXAMPLE OF MY TESTCASE.
<testvar varname="PASS">BADPASSWORD</testvar>
<case
id="1"
verifypositive="DLO"
logresponse="yes"
<case
id="2"
method="get"
url="http://10.251.0.201/webclient/LogOut.php "
posttype="application/x-www-form-urlencoded"
postbody="OLDVALUE_LOGINUSUARIO=&LOGINUSUARIO=${USER}&LOGINPASSWORD=${PASS}={PARSEDRESULT}"
verifynegative="TV"
logresponse="yes"
</testcases>
Sign in
TEST CASE PASSED
<case
id="1"
logresponse="yes"
<case
id="2"
method="get"
verifynegative="TV"
logresponse="yes"
</testcases>
I will check a few things here and see what we can do to help resolve this for you.
Thank you.
Thank you.
I'm really not sure. I'm afraid my experience with WebInject is limited to putting together those example testcases just for the documentation. It appears though that this sort of error is a result of failing to find the string for verification, and then of course failing when it tries to use that in a substitution later. A good place to start would be changing the output format from 'nagios' to I think 'standard', which will let you look through the raw HTTP responses and documents to manually look at the pages and headers coming back to see if they are what you think they should be. We can keep mulling this over, but there is also a WebInject user forum that will probably be able to give you a better answer if you'd be willing to give that a shot - http://www.webinject.org/cgi-bin/forums ... oard=Users.
What we did at our company is we started using Mechanize instead of WebInject. It is easier to understand and modify.tonyyarusso wrote:I'm really not sure. I'm afraid my experience with WebInject is limited to putting together those example testcases just for the documentation. It appears though that this sort of error is a result of failing to find the string for verification, and then of course failing when it tries to use that in a substitution later. A good place to start would be changing the output format from 'nagios' to I think 'standard', which will let you look through the raw HTTP responses and documents to manually look at the pages and headers coming back to see if they are what you think they should be. We can keep mulling this over, but there is also a WebInject user forum that will probably be able to give you a better answer if you'd be willing to give that a shot - http://www.webinject.org/cgi-bin/forums ... oard=Users.
http://search.cpan.org/~petdance/WWW-Me ... chanize.pm
We started trying to use WebInject and realized there was very little documentation to help us through issues.
Thank you for the tip nebias
