Horvath Tamas wrote:
> Hello!
> Thanks. I thought that this is the solution.
> Buti f I change the stylesheet it - perhaps negatively - affects other
> users.
> I just would like to suggest an easy and convenient new feature for future
> releases.
I rather thought about either (mis) using different media stylesheets
(see http://www.w3.org/TR/CSS21/media.html) or using alternate
stylesheets (like By, Tamas
> -----Original Message-----
> From: Arno Lehmann [mailto:[email protected]]
> Sent: Wednesday, June 15, 2005 7:58 PM
> To: Horvath Tamas
> Cc: [email protected]
> Subject: Re: [Nagios-devel] colourblindness issue
> Hello,
> I just stumbled over a mail in the userlist, asking how to change
> colours... and there I had the - probably - right idea.
> Modify the stylesheet Nagios uses. Perhaps adding another one which
> could be seklected by the user is the best solution, but that would
> (probably, I don't know the source) require a patch to the cgis.
> Arno
>>Hi List!
>>I don't exactly know how can I change the colors of Nagios web interface
> to
>>make its usage convenient for a colorblindness man. I just assume, that I
>>have to play with CSS files and with source code of CGIs.
>>May I suggest to make it easier. For example in HP's Network Node Manager
>>(in Solaris version) I can change the colors of the symbols in a text
> file.
>>It would be more wonderful, if I can set these colors in a user by user
>>manner.
>>Thanks in advance, Tamas!
>>SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
>>from IBM. Find simple to follow Roadmaps, straightforward articles,
>>informative Webcasts and more! Get everything you need to get up to
>>speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
>>_______________________________________________
>>Nagios-devel mailing list
>>[email protected]
>>https://lists.sourceforge.net/lists/lis ... gios-devel
IT-Service Lehmann [email protected]
Arno Lehmann http://www.its-lehmann.de
