--------------000201030908020200040109
The correct link is https://intranet.opservices.com.br/phpBB2/
Alessandro Ren wrote:
> We've set up a forum to support opmonagent that can be reached
> here http://intranet.opservices.com.br/phpBB2/
> Thanks.
>> I forgot to mention that we've changed the default TCP port to
>> 5667, as the old 1248 would be in use from time to time on the
>> windows servers.
>> As NRPE default port is 5666 we taught of 5667, but the port can
>> be changed in the register as it can be changed in nsclient, the same
>> way.
>> []s.
>>> The new version of nsclient that we call opmonagent can be
>>> downloaded from
>>> http://www.opservices.com.br/downloads/ ... .2.0.0.zip.
>>> We have fixed the connection limit that nsclient had and fix a
>>> access violation with some global variables that nsclient used.
>>> We've tested it on Windows 2k, XP, 2k3 32bits and 64 bits and
>>> it's running very stable on these platforms.
>>> If someone wants the sourcecode, just drop me a line.
>>> Any suggestions or bug reports are welcome.
>>> Alessandro Ren
> __________________________________________________
> *Alessandro Ren*
> /*OpServices*/
> /*Luciana de Abreu, 471 - Sala 403*/
> /*Porto Alegre, RS - CEP 90570-060*/
> *(* phone 55(51)3061-3588
> *4* fax 55(51)3061-3588
> *Q* mobile 55(48)9987-0625
> *:* email [email protected]
*Alessandro Ren*
/*OpServices*/
Content-Type: text/html; charset=ISO-8859-1
We've set up a forum to support opmonagent that can be reached here
Thanks.
5667, as the old 1248 would be in use from time to time on the windows
servers.
As NRPE default port is 5666 we taught of 5667, but the port can be
changed in the register as it can be changed in nsclient, the same way.
[]s.
downloaded from <a moz-do-not-send="true" class="moz-txt-link-freetext"
href="http://www.opservices.com.br
...[email truncated]...
