>> Following up on my previous message about additive inhereritance it
>> appears
>> that it only applies to the first used instance. Here is an example
>> config
>> that fails. There also appears to be an issue with canceling
>> inheritance.
> [ somewhat bizarre configuration axed out ]
>> Hope this helps track down some potential issues,
> To be perfectly honest, I've always felt it overly complicates the nagios
> config
> parsing code to even allow templates to have templates. For really large
> networks, where they'd obviously be of most use, it's no great chore to
> copy
> and paste one and then modify the variable that you want to alter.
If you have parameters set in a template then if you want to update them you
only have one place to do it. If you have 3k config files (or a 100k file)
then you have thousands of places you have to modify.
> That being said, it looks as if you've run into a bug that nobody has
> noticed
> since february 5 of this year, when Ethan added 'Support for "additive"
> string
> inheritance'.
Glad to be of help. I just started trying to convert our existing config
files over to the 3.x system. I'm trying to take advantage of the way you
can use new templates and noticed a few bugs or inconsistiencies. Thought
I'd pass them along to make the product the best it could be.
> I'm not sure how many people use this feature in an inheritance chain like
> you
> do, and as I personally don't really see the use for it, I'd rather spend
> my time
> on other things.
If they can be fixed our config would benefit from it quite a bit. It would
cut down the amount of manual tweaking necessary to get things to work
right. If something is advertised as working I think it should work or not
be in there.
> I've got some config-parsing patches brewing in my head though,
> and it's possible one of them will fix this issue in passing. For now, I
> think you should
> probably stick to using a single template, and add more templates as you
> go along.
That is basically how we are doing things in 2.x and one of things we were
really looking forward too was the multiple inheritance properties of
templates.
> I'm not a great fan of testing every bizarre configuration users might
> come up with,
> and I think Ethan feels the same, so when you're trying some really exotic
> stuff and
> it happens to not work, you're kinda on your own.
I don't know how bizarre things are. We are trying to template parts of the
stuff and make them work. We put all default parts into a default template.
We put all parts dealing with hours of operation in another template. Where
we ran into problems was trying to get which groups get notified into a
template. It would be nice to be able to include the templates for each
group and have the correct hostgroups and notification group set
automatically with additive.
-Shad
