Content-Type: text/plain; charset=ISO-8859-1
On Tue, May 17, 2011 at 2:27 PM, Andreas Ericsson wrote:
> Ahoy (again).
> [... service sets]
Why not use a "service template on host template" feature instead? The idea
is near the second one you proposed. If you add an host_name to a service
that is a template, it will generate such service for all hosts that will
use this template. So when all your services are defined and lined in the
good host templates you will defined :
define host {
use Linux, Oracle, WhatEver
And the Linux, Oracle, WhatEver are regular host templates, with some
services templates linked for each of them. It's more natural for users to
think about "templates" than to use a new property. So for example the Linu=
x
template will add linux admins as contacts and will add all Linux standard
services checks (/, /var, memory, swap,...).
We already got all elements we need (template on template is not allowed, s=
o
there is no risk in breaking existing configuration), it will be easier for
configuration tools than a new object. It will be just like your solution
N=B02 a little more hard to exchange such "sets" (but in the sample
configuration we can just put a configuration file by sets for example).
It's what we add in Shinken, and it work quite well
Jean
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
--00235446fce4b1a3dd04a3781738
Content-Type: text/html; charset=ISO-8859-1
On Tue, May 17, 2011 at 2:27 PM, Andreas=
Ericsson <[email protected]&=
gt; wrote:
Ahoy (again).
[... service sets]Hi,Why not use a "=
service template on host template" feature instead? The idea is near t=
he second one you proposed. If you add an host_name to a service that is a =
template, it will generate such service for all hosts that will use this te=
mplate. So when all your services are defined and lined in the good host te=
define host {=A0=A0 use Linux, Oracle, WhatEver}And the=
Linux, Oracle, WhatEver are regular host templates, with some services tem=
plates linked for each of them. It's more natural for users to think ab=
out "templates" than to use a new property. So for example the Li=
nux template will add linux admins as contacts and will add all Linux stand=
ard services checks (/, /var, memory, swap,...).
We already got all elements we need (template on template is not allowe=
d, so there is no risk in breaking existing configuration), it will be easi=
er for configuration tools than a new object. It will be just like your sol=
ution N=B02 a little more hard to exchange such "sets" (but in th=
e sample configuration we can just put a configuration file by sets for exa=
mple).
It's what we add in Shinken, and it work quite well :)J=
ean=A0
Andreas Ericsson =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 [email protected]
OP5 AB =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 www.op5.se
Tel: +46 8-230225=
=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0Fax: +46 8-230231
--00235446fce4b1a3dd04a3781738--
