On 11/25/2010 03:51 PM, Deborah Martin wrote:
> I'm using the parameter "service_perfdata_file_processing_command" to
> process performance data for pnp4nagios. The first parameter
> "service_perfdata_command" is commented out. But could I still use that
> first parameter?
Yes. I'm running n2rrd and PNP (bulk mode with npcd) in parallel while
the users are making up their minds whether they want to switch over:
# grep '^service.*command' nagios.cfg
service_perfdata_command=3Dprocess-service-perfdata
service_perfdata_file_processing_command=3Dprocess-service-perfdata-file
# grep -A 1 process-service ../var/objects.cache
command_name process-service-perfdata
command_line /usr/local/n2rrd/bin/n2rrd.pl -N
"/usr/local/nagios/var/spool/status.dat" -C '$SERVICECHECKCOMMAND$' -c
/usr/local/n2rrd/etc/n2rrd.conf -e $SERVICEEXECUTIONTIME$ -l
$SERVICELATENCY$ -T $LASTSERVICECHECK$ -H $HOSTNAME$ -s "$SERVICEDESC$"
-o "$SERVICEPERFDATA$"
command_name process-service-perfdata-file
command_line /bin/mv
/usr/local/pnp4nagios/var/spool/incoming/service-perfdata
/usr/local/pnp4nagios/var/spool/service-perfdata.$TIMET$
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
