[Nagios-devel] true regexp enhancement
after turning thousands of lines when trying the
use_true_regexp_matching i thought if this
feature may be enhanced by surrounding the pattern string automatically
with "^" and "$"
so there is no need to cover each string to prevent double matches. This
may be
configurable.
If i have a host named "linux1" and i have also hosts named "linux10"
and "linux11"
there will be a complain about, that a service for linux10 oder linux11
is already defined,
caused by the service definition for this service when writing
host_name linux1
service_description PING
check_command check_ping...
this will unfortunately math all hosts beginning oder containing "linux1"
If the patterns will be surrounded by begin and end patterns there is no
need to change thousands of
definitions.
Then a match for all hostnames beginning with "linux1" must be written
as "linux1.*" which expicitly says i want
additional characters.
Best Regards
Robert
