Re: [Nagios-devel] ePN and multi line output
On Wed, Dec 26, 2007 at 11:52:32AM -0600, Ethan Galstad wrote:
> I just submitted a patch for p1.pl that I believe fixes this. It worked
> on the sample script you provided at least. Not sure if it'll break
> other Perl scripts, but I don't think it should...
Thank you. I'm running the new p1.pl with 3.0rc1 for more than 12 hours
without real problems.
The output of check_multi does not work correctly, if the output is
formatted with -r2 (HTML formatted). Plain output without HTML Tags is
correct (and HTML format is not really neccessary ;-)
@Matthias: please, could you check your plugin with ePN enabled, HTML
formatting and the new p1.pl?
Wolfgang
* http://www.swobspace.de
Original poster: [email protected] (Wolfgang Barth
