[Nagios-devel] NSCA memory leak
Hi list,
I am running nagios on Gentoo and having an issue with NSCA.
When NSCA is running for a few days I get it crashes with this in dmesg:
localhost nsca[6030]: segfault at ffffffffff600429 ip 00007f8d3ea19dfc sp
00007fff47281350 error 7 in libwrap.so.0.7.6[7f8d3ea16000+8000]
I compiled NSCA in debug mode and ran it with valgrind. We found the =20
following memory
leak:
=3D=3D8837=3D=3D Syscall param fcntl(arg) contains uninitialised byte(s)
=3D=3D8837=3D=3D at 0x553EF5B: fcntl (in /lib64/libc-2.9.so)
=3D=3D8837=3D=3D by 0x402FE1: handle_connection (in /usr/bin/nsca)
=3D=3D8837=3D=3D by 0x403369: accept_connection (in /usr/bin/nsca)
=3D=3D8837=3D=3D by 0x4040D5: main (in /usr/bin/nsca)
=3D=3D8840=3D=3D
=3D=3D8840=3D=3D Syscall param fcntl(arg) contains uninitialised byte(s)
=3D=3D8840=3D=3D at 0x553EF5B: fcntl (in /lib64/libc-2.9.so)
=3D=3D8840=3D=3D by 0x402FE1: handle_connection (in /usr/bin/nsca)
=3D=3D8840=3D=3D by 0x403369: accept_connection (in /usr/bin/nsca)
=3D=3D8840=3D=3D by 0x4040D5: main (in /usr/bin/nsca)
=3D=3D8842=3D=3D
=3D=3D8842=3D=3D Syscall param fcntl(arg) contains uninitialised byte(s)
=3D=3D8842=3D=3D at 0x553EF5B: fcntl (in /lib64/libc-2.9.so)
=3D=3D8842=3D=3D by 0x402FE1: handle_connection (in /usr/bin/nsca)
=3D=3D8842=3D=3D by 0x403369: accept_connection (in /usr/bin/nsca)
=3D=3D8842=3D=3D by 0x4040D5: main (in /usr/bin/nsca)
=3D=3D8838=3D=3D
=3D=3D8838=3D=3D Syscall param fcntl(arg) contains uninitialised byte(s)
=3D=3D8838=3D=3D at 0x553EF5B: fcntl (in /lib64/libc-2.9.so)
=3D=3D8838=3D=3D by 0x402FE1: handle_connection (in /usr/bin/nsca)
=3D=3D8838=3D=3D by 0x403369: accept_connection (in /usr/bin/nsca)
=3D=3D8838=3D=3D by 0x4040D5: main (in /usr/bin/nsca)
=3D=3D8828=3D=3D
=3D=3D8828=3D=3D ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 14 fro=
m 2)
=3D=3D8828=3D=3D malloc/free: in use at exit: 621 bytes in 25 blocks.
=3D=3D8828=3D=3D malloc/free: 115 allocs, 90 frees, 32,290 bytes allocated.
=3D=3D8828=3D=3D For counts of detected errors, rerun with: -v
=3D=3D8828=3D=3D Use --track-origins=3Dyes to see where uninitialised values=
come from
=3D=3D8828=3D=3D searching for pointers to 25 not-freed blocks.
=3D=3D8828=3D=3D checked 124,080 bytes.
=3D=3D8828=3D=3D
=3D=3D8828=3D=3D LEAK SUMMARY:
=3D=3D8828=3D=3D definitely lost: 584 bytes in 22 blocks.
=3D=3D8828=3D=3D possibly lost: 0 bytes in 0 blocks.
=3D=3D8828=3D=3D still reachable: 37 bytes in 3 blocks.
=3D=3D8828=3D=3D suppressed: 0 bytes in 0 blocks.
=3D=3D8828=3D=3D Rerun with --leak-check=3Dfull to see details of leaked mem=
ory.
I then ran with options --leak-check=3Dfull --show-reachable=3Dyes:
=3D=3D21927=3D=3D ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 14 fr=
om 2)
=3D=3D21927=3D=3D malloc/free: in use at exit: 621 bytes in 25 blocks.
=3D=3D21927=3D=3D malloc/free: 96 allocs, 71 frees, 21,932 bytes allocated.
=3D=3D21927=3D=3D For counts of detected errors, rerun with: -v
=3D=3D21927=3D=3D Use --track-origins=3Dyes to see where uninitialised value=
s come from
=3D=3D21927=3D=3D searching for pointers to 25 not-freed blocks.
=3D=3D21927=3D=3D checked 122,080 bytes.
=3D=3D21927=3D=3D
=3D=3D21927=3D=3D
=3D=3D21927=3D=3D 37 bytes in 3 blocks are still reachable in loss record 1 =
of 4
=3D=3D21927=3D=3D at 0x4C24C1E: malloc (in =20
/usr/lib64/valgrind/amd64-linux/vgpreload_memcheck.so)
=3D=3D21927=3D=3D by 0x54F5D31: strdup (in /lib64/libc-2.9.so)
=3D=3D21927=3D=3D by 0x402B6C: read_config_file (in /usr/bin/nsca)
=3D=3D21927=3D=3D by 0x4037DD: main (in /usr/bin/nsca)
=3D=3D21927=3D=3D
=3D=3D21927=3D=3D
=3D=3D21927=3D=3D 584 (104 direct, 480 indirect) bytes in 2 blocks are =20
definitely lost in loss record 2 of 4
=3D=3D21927=3D=3D by 0x555A4AA: (within /lib64/libc-2.9.so)
=3D=3D21927=3D=3D by 0x555AC26: __nss_database_lookup (in /lib64/libc-2.9=
.so)
=3D=3D21927=3D=3D by 0x5BD233F: ???
=3D=3D21927=3D=3D by 0x5BD33D6: ???
=3
...[email truncated]...
