Re: [Nagios-devel] Wildcard in servicegroup causes segmentation
------=_NextPart_000_0025_01C6A405.AFA58590
Content-Type: text/plain;
charset="us-ascii"
I'm not sure if that will help, but can you try the latest 2.x cvs tarball?
You can download it from http://nagios.sourceforge.net/download/cvs/
It fixed a similar segfault for me.
Thomas
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf
> Of Bernd Adamowicz
> Sent: July 10, 2006 8:44
> To: [email protected]
> Subject: [Nagios-devel] Wildcard in servicegroup causes
> segmentation fault
> (Hope I didn't cause too much confusion since I already posted this
> message once bevore beeing a member of this list.)
> Hi All,
> I'm facing the problem, that the pre flight check from nagios causes
> a segmentation fault, if the 'member' variable of a servicegroup
> contains a '*' wildcard. I have just compiled the latest CVS tarball
> because there have been some similiar bugs reported, but it didn't
> fix my problem.
> This is the part of my configuration that causes the problem:
> # causes seg fault
> define servicegroup{
> servicegroup_name Swapspace
> alias Services checking the swap space on
> disk
> members BSS-MGMT-SMServer*,Swapspace
> Of course there is at least one host which matches the
> pattern 'BSS-MGMT-
> SMServer*,'.
> Seems the '*' after 'BSS-MGMT-SMServer' causes the problem. If I
> switch to a single host name, everything works fine:
> # causes no seg fault
> disk
> members BSS-MGMT-SMServer-Test04b,Swapspace
> I run Nagios in GDB. This is the output:
> >nagios-2-x-cvs/base # gdb nagios
> (gdb) run -v /usr/local/nagios/etc/nagios.cfg
> Starting program: /root/temp/nagios-2-x-cvs/base/nagios -v
> /usr/local/nag
> ios/etc/nagios.cfg
> [Thread debugging using libthread_db enabled]
> [New Thread 182901004448 (LWP 424)]
> Nagios 2.4
> Copyright (c) 1999-2006 Ethan Galstad (http://www.nagios.org)
> Last Modified: 05-31-2006
> License: GPL
> Reading configuration data...
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 182901004448 (LWP 424)]
> 0x0000002a95a452c5 in free () from /lib64/tls/libc.so.6
> (gdb)
> -------- end of gdb output
> Maybe this will give someone of you a hint, what might have happened.
> (I was a little bit confused about the last modified date of
> 05-31-2006,
> but I'm shure I got the latest tarball.)
> Maybe someone has help. Thanks in advance.
> - Bernd Adamowicz (Bernd)
> The mailing list archive is found here:
> http://www.nagiosexchange.org/nagios-devel.33.0.html
> Using Tomcat but need to do more? Need to support web
> services, security?
> Get stuff done quickly with pre-integrated technology to make
> your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on
> Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... bid=263057&
dat=121642
> Nagios-devel mailing list
> [email protected]
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
filename="smime.p7s"
MIAGCSqGSIb3DQEHAqCAMIACAQExCzAJBgUrDgMCGgUAMIAGCSqGSIb3DQEHAQAAoIIIwTCCAkkw
ggGyoAMCAQICAw+pBzANBgkqhkiG9w0BAQQFADBiMQswCQYDVQQGEwJaQTElMCMGA1UEChMcVGhh
d3RlIENvbnN1bHRpbmcgKFB0eSkgTHRkLjEsMCoGA1UEAxMjVGhhd3RlIFBlcnNvbmFsIEZyZWVt
YWlsIElzc3VpbmcgQ0EwHhcNMDUxMDEzMjE1NDQ2WhcNMDYxMDEzMj
...[email truncated]...
