Stephen Gran wrote:
> On Thu, Sep 30, 2010 at 02:31:55PM -0700, Mark Christian said:
>> I updated nagios from 3.2.0 to 3.2.2 - my distributed "collector" node
>> went from ~7000 services passively checked and near zero actively
>> checked to ~1800 actively checked and counting.
> The fix for this has already been checked into cvs.
Sure thing. But how to support the community (e.g. in IRC) by telling
them "delete sth in the code and then recompile". This remains a major
bug and should be fixed in a release soon. Also within already created
packages and so on.
In the Opsview repository, a patch for this is accessible, but I think
the community wouldn't mind getting the "host checks skipped" bug fixed
too within Nagios 3.2.3 - would create a nice release blog post and a
bit more focused on development than keeping other issues with more
priority as it seems.
If you require more test reports (as Tony stated on IRC that Ethan wants
that): The fix has been tested and debugged on Icinga Core, same
behavior, same bugfix, same successful tests. If needed, I'll clone
Andreas' GIT and run several tests against Nagios Core too, but since
the code in this regard is merely the same, putting that up to a release
should be no problem. But if you do think different, no offense taken.
Kind regards,
Michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
fax: +43 1 4277 14279
web: http://www.univie.ac.at/zid
Icinga Core& IDOUtils Developer
http://www.icinga.org
