Is there anything that would allow for a passive check to notify you if it
hadn't been updated in a specified period? For instance, if the passive check
was not updated in 15 minutes, notify that there could be a problem or WARNING?
-bk
Quoting Dougal Scott :
> A few points on passive checks:
> * The scheduler should ignore passive checks in all its
> calculations as it doesn't have to schedule a check of them. If
> you have, like we do, a _lot_ more passive checks than active ones then
> it skews all the calculations badly.
> * Passive only checks still get added to the scheduler so it still
> runs the check_command. Whereas netsaint wouldn't run passive
> checks because you put them in a non-occuring timezone, nagios
> removed that obfuscation and let you specify that a check was
> passive. At least according to the documentation that is. Did the
> source get updated to reflect this?
> Dougal Scott Connect Internet Solutions
> [email protected] 9/114 Albert Rd
> Senior Systems Administrator South Melbourne, Australia, 3205
> This sf.net email is sponsored by:ThinkGeek
> Welcome to geek heaven.
> http://thinkgeek.com/sf
> Nagios-devel mailing list
> [email protected]
