Re: [Nagios-devel] Call for configs
Hi Andreas,
this is a diff to make it work with POSIX tools (tested on OpenBSD) and
adding more anonymization (notes_url and comments):
--- nagios-anonymizer.sh Tue Aug 28 12:03:11 2012
+++ nagios-anonymizer-portable.sh Tue Aug 28 12:33:09 2012
@@ -32,11 +32,11 @@
sed -n "s/^Processing object config file '\([^']*\)'.*/\1/p" vs-output > oconf-files
echo "Concatenating and minimizing object config"
-sed 's/^[\t ]*//' $(cat oconf-files) > objects.cfg
+sed 's/^[[:space:]]*//' $(cat oconf-files) > temp.cfg
echo "Anonymizing..."
-sed -i \
- -e 's/^address[\t ].*/address ANON/' \
+sed \
+ -e 's/^address[[:space:]].*/address ANON/' \
-e 's/^email.*/email ANON/' \
-e 's/^pager.*/pager ANON/' \
-e 's/address[1-7].*/address ANON/' \
@@ -45,7 +45,9 @@
-e 's/^\(host_notification_commands\).*/\1 host-notifyANONYMIZED/' \
-e 's/^\(service_notification_commands\).*/\1 service-notifyANONYMIZED/' \
-e 's/^\(command_line\).*/command_line ANONYMIZED/' \
- objects.cfg
+ -e 's/^notes_url.*/notes_url ANON/' \
+ -e 's/^#.*//' \
+ temp.cfg > objects.cfg
c=$(grep -c ANON objects.cfg)
echo "Anonymized $c strings"
@@ -58,7 +60,7 @@
fi
echo "Done :)"
-size=$(stat $anon_cfg_file | sed -n 2p | awk '{ print $2 }')
+size=$(wc -c $anon_cfg_file | awk '{ print $1 }')
echo "Successfully created $workdir/$anon_cfg_file"
if test $size -gt 10000000; then
echo "The file is larger than 10MB, so please attach it to a dropbox"
Regards,
Armin Wolfermann
