--089e012942aa9d05dd04e52988e8
Content-Type: text/plain; charset=ISO-8859-1
On Fri, Aug 30, 2013 at 2:18 PM, Andreas Ericsson wrote:
> On 2013-08-29 14:42, Mattias Ryrl=E9n wrote:
>> commit f0054ac856059183f6c7bc3f9e8a80**965a8c0368 (HEAD, master)
>> Author: Mattias Ryrl=E9n
>> Date: Thu Aug 29 14:34:39 2013 +0200
>> YES! test: build on machines with only one cpu
>> There might be someone out there who still have only one cpu/core,
>> let
>> those
>> build too.
>> Signed-off-by: Mattias Ryrl=E9n
> While I sort of agree that tests should pass on single-cpu machines as
> well, this change renders the whole test useless, since we *always*
> return > 0 from online_cpus().
> Adding a function (real_online_cpus()) which returns 0 when it can't
> reliably test for number of online cpus, and letting that be wrapped
> by online_cpus() so that the latter can retain its current behaviour
> would solve the problem. online_cpus() should then look like this:
> unsigned int online_cpus(void)
> unsigned int cpus =3D real_online_cpus();
> return cpus ? cpus : 1;
> while the new function real_online_cpus() must take the body of the
> current online_cpus() function but be changed so that the fallback is
> to return 0. The test must then be changed to use real_online_cpus()
> instead.
> Would you like to reroll, or should I make the necessary changes and
> credit you with an "Reported-by"?
I reroll, have enough lvl80 chars anyway..
> diff --git a/lib/test-nsutils.c b/lib/test-nsutils.c
>> index 1a23ee1..f835d67 100644
>> --- a/lib/test-nsutils.c
>> +++ b/lib/test-nsutils.c
>> @@ -31,10 +31,10 @@ int main(int argc, char **argv)
>> asprintf(&s1, "arg varg foo %d", 12);
>> s2 =3D mkstr("arg varg foo %d", 12);
>> ok_str(s1, s2, "mkstr() must build proper strings");
>> - if (online_cpus() > 1) {
>> + if (online_cpus() > 0) {
>> t_pass("%d online cpus detected", online_cpus());
>> } else {
>> - t_fail("Do you really have only one cpu core?");
>> + t_fail("No online cpus detected");
>> return t_end();
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
--=20
V=E4nliga h=E4lsningar / Best Regards
Mattias Ryrl=E9n
__________________________
op5 AB
F=F6rsta L=E5nggatan 19
SE-413 27 G=F6teborg
Mobil: +46 735-17 70 99
Support: +46 31-774 09 24
www.op5.com
Content-Type: text/html; charset=ISO-8859-1
On Fri, Aug 30, 2013 at 2:18 PM, Andreas Ericsson <[email protected]> wrote:
On 2013-08-29 14:42, Matti=
as Ryrl=E9n wrote:
commit f0054ac856059183f6c7bc3f9e8a80965a8c0368 (HEAD, master)
Author: Mattias Ryrl=E9n <[email protected]>
Date: =A0 Thu Aug 29 14:34:39 2013 +0200
=A0 =A0 =A0YES! test: build on machines with only one cpu
=A0 =A0 =A0There might be someone out there who still have only one cpu/cor=
e, let
those
=A0 =A0 =A0build too.
=A0 =A0 =A0Signed-off-by: Mattias Ryrl=E9n <[email protected]>
...[email truncated]...
