native DB support of any kind for object definitions, as I don't
believe the benefits outweigh the problems that will occur when
fields are added or changed in object definitions. I would use an
script to generate a config file from the DB as Subhendu suggested.
On 4 Mar 2002 at 17:53, Subhendu Ghosh wrote:
> You would need to write some interface code to do that. Also be aware
> that Nagois may not support db interface in the future as db and template
> based config are hard to manage simultaneously. We may be going more
> towards proposing external scripts to generate the template based config
> file from other db data sources independent of Nagios.
> Ethan might confirm or deny this
> -sg
> On Mon, 4 Mar 2002, Boutwell, George wrote:
> > How can I/should I go about getting Nagios/Netsaint information in and out of
> > an external Database other than MySQL or PostgreSQL? (Specifically
> > InterBase or Firebird DBs)
> > Thanks,
> > George
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
> Subhendu Ghosh ([email protected])
> A celebrity is a person who is known for his well-knownness.
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
