The value for last_update in status.dat is the same for all records on our =
installation (30,000 services, 3300 hosts on 2.7- yes, I know it's old). A=
re there instances where this would not be the case? It seems that it would=
have been much more efficient to just put the last_update in the file once=
at the top if it is always the same for each record. Then things like diff=
and rsync of the status.dat file would be *significantly* better. Is there=
a possible use of the last_update field that I'm unaware of that would mak=
e a single last_update entry for the file be a bad idea?
Cary Petterborg
[email protected]
NOTICE: This email message is for the sole use of the intended recipient(s=
) and may contain confidential and privileged information. Any unauthorized=
review, use, disclosure or distribution is prohibited. If you are not the =
intended recipient, please contact the sender by reply email and destroy al=
l copies of the original message.
