Re: [Nagios-devel] Reassemble config files automatically
> you want to see your configuration without templates?
> Have you had a look into the objects.cache file?
>=20
> Maybe you can extract your needed information there.
Yes indeed. That should to the trick.
Thanks!
Jelle
