On 11/02/2010 07:23 PM, Vágó Tibor wrote:
> Hi Andreas,
> ok, thanks for your information.
I've had a peak. The patch is extremely weirdly indented, making
it hard to follow. Spaces are mixed with tabs and the tabsetting
seems to be non-standard.
Re-indent your parts of the code to either match the current
coding standards or to match those used in the linux kernel
project and re-submit a new diff. Then I'll have a look again.
OP5 AB www.op5.se
on peace.
