[Nagios-devel] Nagios development moving forward
just some feedback from my side on your patches.
-------- Original Message --------
Subject: [Nagios-devel] Nagios development moving forward
To: nagios-devel ,
[email protected]
Date: 2010-04-29 20:46
> So for those of you who wish to try out a revamped Nagios with a
> bunch of bugfixes and code improvements, clone your repo from me
> or Ton today and build Nagios from source.
I've taken all your commits and applied them manually onto the current
Icinga Core (we changed things, Nagios did not, and next to that, I'd
like to understand what you and Toon hacked there ;-)
Your hackings are very very nice, and it's a real good start in fixing
things and getting rid of old grown code and workarounds.
This commit is just WOW :-)
http://git.op5.org/git/?p=nagios.git;a= ... 3aa5a0edb9
Regarding taking over commits, kudos have been kept both within commit
subjects and changelog for our next release including your patches next
to ours.
From the testing arena, everything runs fine. Although the sync
retention feature is only one half of the good, the other would be
opsview or some nifty hacking on distributed monitoring :) Everything
else resolves as it should be.
By chance, get these changes into a revamped tar.gz and hand that to
packagers, if it does not get into current CVS head. Or at least the
patch set :)
Kind regards,
Michael
> To clone a repository with git, use
> git clone
> This will get you all latest sources. For further info about git,
> see http://www.git-scm.org
> My repo:
> clone url:
> git://git.op5.org/nagios.git
> gitweb url's:
> http://git.op5.org/git/?p=nagios.git;a= ... /heads/dev
> branches:
> master Same as the still-official Nagios CVS repo
> dev My changes on top of CVS import
> ae-ton The merged state between me and Ton
> Ton's repo:
> clone url:
> git://github.com/tonvoon/opsview-nagios.git
> gitweb url:
> http://github.com/tonvoon/opsview-nagios.git
> branches:
> master Ton's and my changes on top of CVS import
> Those of you who have reported bugs to tracker.nagios.org should
> log into the tracker again and see if your bug has been closed or
> resolved, and if so try out my dev branch, which should contain
> the proper fix.
> Those of you who are git-savvy since before can try
> git log -p --grep="fix.*#$bug_id_without_leading_zeroes" dev
> in a repo cloned from mine and it'll show you the commits that
> are responsible for fixing your problem.
DI (FH) Michael Friedrich
[email protected]
Tel: +43 1 4277 14359
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
