> Hi,
> Matthias Eble schrieb am 21.02.2008 16:57 Uhr:
>> Hi Ethan, hi list,
>> I found the internal _NRPE_CHECK command in the nrpe sources some months
>> ago and found it very useful.
>> It can be used to remotely query nrpe's version:
>> # check_nrpe -H somehost -c _NRPE_CHECK
>> NRPE v2.8.1
> Doesn't "check_nrpe -H somehost" do exactly the same?
well, yes because
#define DEFAULT_NRPE_COMMAND "_NRPE_CHECK" /* check version of NRPE
daemon */
(command_name==NULL)?DEFAULT_NRPE_COMMAND:command_name);
However, I couldn't find any documentation about it.
check_nrpe --help only defines -c to be optional.
