Ton Voon wrote:
> Hi!
> I've added in most of the "easy" patches from Opsview's shallow fork
> of Nagios. All changes have had a test case added. It's funny how I
> feel I have to do more testing when I'm putting changes into the core
> Nagios, even though the same patches have been used in Opsview for
> years.
> The next step is to add libtap to test C functions. In the Nagios
> Plugins, Thomas Guyot-Sionest has copied the libtap library (http://jc.ngo.org.uk/trac-bin/trac.cgi/wiki/LibTap
> ) and amended the configure script to compile this if requested. I'd
> like to do something similar to Nagios. This means that by default,
> nothing should be different, but if --enable-libtap is entered, then
> the local libtap will be compiled and tests can then be run knowing
> that libtap will be available.
> Are there any objections before I add this in?
Go right ahead imo.
