Re: [Nagios-devel] [Nagios-users] Read Only CGI Patch
All,
On Nagios 2.9, I was able to perform the Nagios Read Only CGI patch and
run "make cgis" without any errors.
But I am just slightly afraid of running "make install-cgis" now since
the patch is really for Nagios 3.0.3.
Has anyone else out there done this?
Mike
Mike Seda wrote:
> All,
> I came across the following link recently, and it seems that the Nagios
> Read Only CGI patch is exactly what I need:
> http://eluted.net/index.php/blue/commen ... 03_updated
> Does anyone know if this patch is compatible with Nagios version 2.9?
> The patches seemed to work just fine, but I received errors when running
> the make afterwards.
> If it turns out that this patch is incompatible with Nagios version 2.9,
> then can someone provide a link to a compatible Nagios Read Only CGI
> patch version?
> Mike
> Crystal Reports - New Free Runtime and 30 Day Trial
> Check out the new simplified licensing option that enables unlimited
> royalty-free distribution of the report engine for externally facing
> server and web deployment.
> http://p.sf.net/sfu/businessobjects
> Nagios-users mailing list
> [email protected]
> https://lists.sourceforge.net/lists/lis ... gios-users
> ::: Please include Nagios version, plugin version (-v) and OS when reporting any issue.
> ::: Messages without supporting info will risk being sent to /dev/null
