Re: [Nagios-devel] Daemonizing Logic Error
Devin Bayer wrote:
> Hi Andreas Ericsson:
> On Sat, 2009-05-16, at 13:55, Andreas Ericsson wrote:
>> Devin Bayer wrote:
>>> We faced an issue when nagios silently failed to fork. Since it's
>>> part of our startup scripts, this delayed the rest of the daemons
>>> until nagios exited.
>> While it's bad that Nagios fails to daemonize OR die properly, your
>> startup-script parser really shouldn't hang indefinitely when it
>> encounters a start-script that doesn't return. I believe this should
>> be bug-reported to your distribution-vendor separately.
> I agree - but this is RHEL5, and it is not a new class of bug. The
> fact that it isn't already fixed means it's a policy: daemons are
> responsible for exiting timely.
Ok. I can sort of agree with them, but still. Hanging *indefinitely* is
just bad form ;-)
>> Hmm. I'll look into this and see what may be done.
> Thanks a lot. Do you have some kind of tracking system, so I can know
> when/if it's fixed?
tracker.nagios.org. Issue 11.
> - Devin
> Crystal Reports - New Free Runtime and 30 Day Trial
> Check out the new simplified licensing option that enables
> unlimited royalty-free distribution of the report engine
> for externally facing server and web deployment.
> http://p.sf.net/sfu/businessobjects
> Nagios-devel mailing list
> [email protected]
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
