Re: [Nagios-devel] Date in Log File
Steve Pribyl wrote:
> Is there any reason the log file using the epoch time instead of a human
> readable format?
You can configure nagios to log to syslog in the main config file. Then
you have a human readable timestamp. If you use syslog-ng it is easy to
use a filter with program('nagios') to put all log from nagios to a
separate file.
