[Nagios-devel] PATCH: Allow escaping ! in check args (utils.c)
------=_20060515151502_30858
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
Gents,
Please find attached a patch (in unified diff context,) for the following:
My work had me create a patch for the get_raw_command_line() function in
utils.c to allow us to "escape" the "!" argument separator within check
command arguments.
I generalized it such that you can actually escape any character by
prefacing it with a backslash ('\'). So, now you can have command args
that include exclamations points as part of the argmument string.
For example:
check_command check_web!www.nagios.org!80!\!Test\!String\!!10!20
This will pass the third argument as: "!Test!String!" (sans quotes)
Bob
Content-Type: text/plain; name="utils.c.diff"
Content-Disposition: attachment; filename="utils.c.diff"
--- utils.c 2006-04-07 15:45:33.000000000 -0600
+++ ../../nagios-2.2/base/utils.c 2006-04-20 13:21:29.000000000 -0600
@@ -2937,6 +2937,7 @@
command *temp_command;
int x,y;
int arg_index;
+ int escape_me;
#ifdef DEBUG0
printf("get_raw_command_line() start\n");
@@ -2969,9 +2970,19 @@
/* lookup the command... */
/* get the command name */
- for(x=0,y=0;y<buffer_length-1;x++){
- if(cmd[x]=='!' || cmd[x]=='\x0')
- break;
+ escape_me = 0;
+ for(x=0,y=0;y<buffer_length-1 && cmd[x];x++){
+ if (!escape_me) {
+ if (cmd[x]=='\\') {
+ escape_me = 1;
+ continue;
+ if(cmd[x]=='!')
+ break;
+ else
+ escape_me = 0;
raw_command[y]=cmd[x];
y++;
@@ -2989,9 +3000,18 @@
strip(raw_command);
/* skip the command name (we're about to get the arguments)... */
- for(arg_index=0;;arg_index++){
- if(cmd[arg_index]=='!' || cmd[arg_index]=='\x0')
- break;
+ escape_me = 0;
+ for(arg_index=0; cmd[arg_index]; arg_index++){
+ if (!escape_me) {
+ if (cmd[arg_index]=='\\') {
+ escape_me = 1;
+ continue;
+ if(cmd[arg_index]=='!')
+ break;
+ else
+ escape_me = 0;
/* get the command arguments */
@@ -3003,9 +3023,18 @@
/* get the next argument */
/* can't use strtok(), as that's used in process_macros... */
- for(arg_index++,y=0;y<sizeof(temp_arg)-1;arg_index++){
- break;
+ escape_me = 0;
+ for(arg_index++,y=0; y<sizeof(temp_arg)-1 && cmd[arg_index]; arg_index++){
+ if (!escape_me) {
+ escape_me = 1;
+ continue;
+ break;
+ else
+ escape_me = 0;
temp_arg[y]=cmd[arg_index];
y++;
@@ -3017,6 +3046,9 @@
strip(arg_buffer);
macro_argv[x]=strdup(arg_buffer);
+#ifdef DEBUG1
+ printf("\ttempArg[%d]: %s\n",x,temp_arg);
+#endif
#ifdef DEBUG1
------=_20060515151502_30858--
