Re: [Nagios-devel] Non existent macros are not replaced
On 03/03/2011 05:39 PM, Matthieu Kermagoret wrote:
> Hi list,
> When using a non-existent macros in a command (like for example
> $SERVICEDESC$ in a host notification command), such macro is not
> replaced. It is instead left as-is on the command line.
> Such construct is interpreted by the shell as a variable (usually
> empty) followed by a dollar sign which (usually) expands to a single
> dollar and lead users to believe that Nagios replace non-existent
> macros with a single dollar (see ticket #34
> http://tracker.nagios.org/view.php?id=34).
> I believe this behavior is not intuitive and should therefore be
> modified to simply remove non-existent macros, as the attached patch
> does.
> What do you think about it ?
I think that would be quite stupid, as it would prevent users from
using shell variables in their commands, or multiple dollar-signs
for that matter. A completely unnecessary complication which would
only serve to limit Nagios' capabilities as a protection from a
completely harmless error caused by not RTFM'ing before typing.
While protecting users from making too many or too grave mistakes
is a fine thing indeed, it can be taken too far.
OP5 AB www.op5.se
on peace.
