Re: [Nagios-devel] Bug in escalation template handling
Darren, perhaps you mean to use 'hostgroupescalation { .. }' ?
On Thu, Jul 22, 2004 at 03:08:13PM -0008, Darren White wrote:
> I sent this on this list a couple of weeks ago, but nobody responded.
> How/Where should bug reports be submitted, and is this a known
> issue/already corrected?
> > As best I can tell, this is an undocumented bug.
> > Host escalations do not support hostgroup_name in template
> > definitions. Read on for an explanation.
> > When defining a serviceescalation, you can use a host_name or a
> > hostgroup_name to specify which host(s) the escalation applies to. If you
> > define a template (register 0) and then "use" it in a serviceescalation,
> > it works with either a host_name or a hostgroup_name in the template
> > definition.
> > When defining a hostescalation, you can use a host_name or a
> > hostgroup_name as well, to specify the host(s) it applies to. When
> > you use a template, if you specify host_name in the template,
> > everything works. If you use hostgroup_name, nagios complains
> > about the host_name parameter being Null.
> > Confirmed with Nagios 1.0 and 1.2.
> Darren White
> InterStar Inc.
> 530-224-6866 x 103
> This SF.Net email is sponsored by BEA Weblogic Workshop
> FREE Java Enterprise J2EE developer tools!
> Get your free copy of BEA WebLogic Workshop 8.1 today.
> http://ads.osdn.com/?ad_id=4721&alloc_id=10040&op=click
> Nagios-devel mailing list
> [email protected]
Joe Rhett
Senior Geek
Meer.net
