--0-1431223482-1234532733=:33898
Content-Type: text/plain; charset=utf-8
Hi'
For passive only services I would like to use option
check_period=C2=A0=C2=A0 none
instead of option
=C2=A0=20
active_checks_enabled=C2=A0=C2=A0 0
since the latter gives rise to showing these checks as disabled in the
"tactical overview", which the former does not. It is less confusing
for our operators to not see anything being disabled.
Now I have spiced these passive only checks up with freshness checkings, se=
e docs/freshness.html, but it seems, that this only works, if I use "active=
_checks_enabled 0" instead of "check_period none". One might suspect that, =
but docs/timeperiods.html states, that "Note: On-demand checks and passive =
checks are not restricted by the timeperiod you specify in the check_period=
directive. Only regularly scheduled active checks are restricted.". Would =
you think, that freshness checking should also fall under that category.
Also, the FAQ at http://www.nagios.org/faqs/viewfaq.php? ... 71&expand=
=3Dfalse&showdesc=3Dfalse seems to indicate, that using "check_period none"=
would be the right thing to do, but maybe that was true only in an earlier=
release.
Best regards.
Thomas.=0A=0A=0A _____________________________________________________=
___ =0AAudi, Fiat, Peugeot, Skoda, Porsche, Toyota, Ford - Kelkoo har brugt=
e biler til en hver smag! Klik her for at sammenligne priser.(http://dk.yah=
oo.com/r/pat/mmb)
Content-Type: text/html; charset=utf-8
Hi'For passive only services I would =
like to use optioncheck_period noneinstead of o=
ption active_checks_enabled 0since the la=
tter gives rise to showing these checks as disabled in the"tactical ove=
rview", which the former does not. It is less confusingfor our operator=
s to not see anything being disabled.Now I have spiced these passiv=
e only checks up with freshness checkings, see docs/freshness.html, but it =
seems, that this only works, if I use "active_checks_enabled 0" instead of =
"check_period none". One might suspect that, but docs/timeperiods.html stat=
es, that "Note: On-demand checks and passive checks are not restricted by t=
he timeperiod you specify in the check_period directive. Only regularly sch=
eduled active checks are restricted.". Would you think, that freshness
checking should also fall under that category.Also, the FAQ at htt=
p://www.nagios.org/faqs/viewfaq.php?faq_id= ... false&sho=
wdesc=3Dfalse seems to indicate, that using "check_period none" would be th=
e right thing to do, but maybe that was true only in an earlier release.Best regards.Thomas.=0A=0A=0A =0AAudi, Fiat, Peugeot, Skoda, Porsche, Toyota,=
Ford - Kelkoo har brugte biler til en hver smag! Klik her for at sammenligne priser. =
=0A
--0-1431223482-1234532733=:33898--
