Re: [Nagios-devel] Any interest in Patch to Allow Escaping Characters
Bob Ingraham wrote:
> Gents,
> My work had me create a patch for the get_raw_command_line() function in
> utils.c to allow us to "escape" the "!" argument separator within check
> command arguments.
> I generalized it such that you can actually escape any character by
> prefacing it with a backslash ('\'). So, now you can have command args
> that include exclamations points as part of the argmument string.
> For example:
> check_command check_web!www.nagios.org!80!\!Test\!String\!!10!20
> This will pass the third argument as: "!Test!String!" (sans quotes)
> Bob
Sounds interesting - send the patch to the list and I'll look at it for
inclusion in Nagios 3.x. Thanks!
Ethan Galstad,
Nagios Developer
Email: [email protected]
