--------------030106020203050805090305
Content-Type: text/plain; charset=UTF-8; format=flowed
Content-Transfer-Encoding: 8bit
Sorry, Phil, but I'm still not able to reproduce it. I tried using the
check_esxi_hardware.py plugin and I get the following displayed in the
'Status Information' column on the status.cgi:
OK - Server: Dell Inc. PowerEdge
T710 s/n: xxxxxxxx
System BIOS: 6.0.7 2011-08-18
Can you send the applicable configs?
Eric
On 3/7/13 6:48 AM, Randal, Phil wrote:
> ./check_openmanage -H hc-server -I
> OK - System: 'PowerEdge 1955', SN: 'xxxxxxx', 16 GB ram (8 dimms), 1 logical drives, 2 physical drives
> The href lines are what are getting mangled (appended in quotes) to the base cgi url
> Both 3.4.4 and 3.4.5rc1 work fine.
> It's my own rpm build, but that shouldn't make any difference.
> Cheers,
> Phil
> -----Original Message-----
> From: Eric Stanley [mailto:[email protected]]
> Sent: 07 March 2013 12:03
> To: [email protected]
> Subject: Re: [Nagios-devel] Nagios Core 3.5.0rc1
> Thanks for the report, Phil.
> I'm having a hard time guessing what might have broken that between
> 3.4.4 and now. I did a quick test using check_dummy and I don't see the issue.
> Are you running 3.4.4? If not, what version are you running where it works correctly? Also, where do you see the broken URL?
> Could you send me the output of the plugin(s) run from the command line?
> Thanks,
> Eric
> On 3/5/13 11:53 AM, Randal, Phil wrote:
>> 3.5.0rc1 breaks check_openmanage output (and check_esxi_hardware.py
>> output in the same way)
>> A link which should be, for example,
>> http://support.dell.com/support/edocs/systems/peR815/
>> gets mangled into something liek
>> http:///nagios/cgi-bin/"http://support.dell.com/support/edocs/systems/peR815/"
>> Cheers,
>> Phil
>> Sent: 28 February 2013 11:59
>> To: Nagios Developers List
>> Subject: [Nagios-devel] Nagios Core 3.5.0rc1
>> Sorry for multiple release candidates, but I fixed two more issues with the CGIs that are very closely related to issues fixed in the 3.4.5rc1 tarball.
>> The release has also been bumped to 3.5.0 because of an ABI change. (It should have been bumped prior to 3.4.5rc1.) The downtime structure had a member added to help resolve the downtime notification problem. This means that modules will need to be recompiled to use this version.
>> You can download the 3.5.0rc1 tarball from http://sourceforge.net/projects/nagios/ ... z/download.
>> Feel free to compile it and try it (on a test system, please). The 3.4.5 candidate did not generate much feedback and I'm hoping no news is good news. The changes between 3.4.5rc1 and 3.5.0rc1 are relatively minor, so I don't plan to wait long until releasing 3.5.0.
>> The complete changelog since 3.4.4 is as follows:
>> * Fixed bug #403: The "configuration" page of the webui doesn't use
>> entity encoding when displaying the "command expansion" item (Eric
>> Stanley)
>> * Fixed bug #424: Nagios Core 3.4.4 seg fault (core dump) on restart
>> after removing config for running service (Eric Stanley)
>> * Updated CGI utility functions to support UTF-8 characters (Eric
>> Stanley)
>> * Fixed bug where selecting Command Expansion from Configuration CGI
>> page would display commands instead (Eric Stanley)
>> * Fixed bug #369: status.cgi crashes with segfault when there are
>> german ulauts (äöüß) in the hostname or the servicename (Eric Stanley)
>> * Fixed bug #418: Scheduled Downtime
...[email truncated]...
Original poster: a class="moz-txt-link-freetext" href="mailto:[email protected]">mailto:[email protected]
