Sorry, no, it's Nagios 2 only. It does support mysql, though.
On Tue, 22 Feb 2005, Winkles, William (Bill) wrote:
> Ben,
> Thanks for the good info. I will start playing with this package tonight.
> I currently have Nagios 1.2 compiled with MySQL. I'm assuming that this
> will work with 1.2, do you know?
> Thanks again.
> Bill
> -----Original Message-----
> From: Ben [mailto:[email protected]]
> Sent: Tuesday, February 22, 2005 2:01 PM
> To: Winkles, William (Bill)
> Cc: [email protected]
> Subject: Re: [Nagios-devel] Reporting Trends on a Host Group
> I do this, but I'm running Nagios 2 with the Nagios-DB stuff. Because all
> the availability data is kept in SQL, it makes harvesting data for such
> reports pretty easy.
> http://sourceforge.net/projects/nagios-db/
> Nagios-DB was designed to replace the CGI interface, but it doesn't modify
> them at all, so you could keep using them if you want, and just pull data
> out of the database when you want to run special reports.
> > All,
> > I am interested in using the Nagios Reporting Trends on a host group. I
> > understand that it would take some time to generate the graphs for all of
> > the hosts in the host group, but it seems better than manually doing it 1
> > host at a time.
> > Has anyone done this in the past? It doesn't necessarily have to be
> > reported in the web interface. I could create the reports with an
> outputted
> > txt or csv file.
> > Any help or suggestions are appreciated.
> > Thanks.
> > Bill
