I have recommended & used Nagios for a number of years. Finally in my current contract I have done a full setup on Nagios XI.
I have added all of our hosts (Windows 2008 based) and just used the standard options for monitoring (CPU, hdd space, ram usage).
What I thought at the time was - I'll add in services to monitor on set servers at a later time. Thing like spooler service, some Citrix core services and also some application core services that should always be up & running.
However... I can't find a guide to show me how to do this. The initial wizard to monitor a host is awesome - and had a section for adding services that made the process very easy. However I can't find the same guide for simply adding a service to be monitored on a set host.
I have gotten as far as going in to the Nagios core config manager, monitoring\services - filtered for a host I want and clicked "add"
The common settings are ok... until I get to the check command.
It is not clear which command should be used or what arguments should be used if any.
Is there a wizard to add monitors to a host or something???
Any help would be great. Thanks.
