When Nagios is running and I run the ndomod daemon. This is what netstat -a
shows:
*.5668 *.* 0 0 49152 0 LISTEN
msutil1.56264 msutil1.5668 2069 0 49152 0
CLOSE_WAIT
msutil1.5668 msutil1.56264 49152 0 2069 0
FIN_WAIT_2
CLOSE_WAIT
-----Original Message-----
[mailto:[email protected]] On Behalf Of Evans,
Drexter
Sent: Wednesday, June 06, 2007 12:45 PM
To: Nagios Developers List
Subject: Re: [Nagios-devel] ndoutils1.4b3 issue with writing to mysql dbas e
This is what the ndo.dat file looks like:
HELLO
PROTOCOL: 2
AGENT: NDOMOD
AGENTVERSION: 1.4b3
STARTTIME: 1181151503
DISPOSITION: REALTIME
CONNECTION: FILE
CONNECTTYPE: INITIAL
INSTANCENAME: default
STARTDATADUMP
...snipet
300:
4=1181151504.98808
21=/opt/ACSnagios/etc/nagios.cfg
22=cfg_file=/opt/ACSnagios/etc/host_templates.cfg
22=cfg_file=/opt/ACSnagios/etc/hosts.cfg
22=cfg_file=/opt/ACSnagios/etc/commands.cfg
22=cfg_file=/opt/ACSnagios/etc/timeperiods.cfg
22=cfg_file=/opt/ACSnagios/etc/contactgroups.cfg
22=cfg_file=/opt/ACSnagios/etc/contacts.cfg
22=cfg_file=/opt/ACSnagios/etc/hostgroups.cfg
22=cfg_file=/opt/ACSnagios/etc/service_templates.cfg
22=cfg_file=/opt/ACSnagios/etc/services.cfg
22=cfg_file=/opt/ACSnagios/etc/servicegroups.cfg
...snipet
202:
1=300
2=0
3=0
4=1181151504.103504
73=1181151504
74=64
72=Finished daemonizing... (New PID=3875)
999
...snipet
212:
1=1201
2=0
3=0
4=1181151504.115547
53=acsmsvtf01
95=DISK OK - free space: / 5063 MB (54% inode=90%): /boot 84 MB (60%
inode=99%): /fx_work0 18361 MB (98% inode=99%): /de
v/shm 928 MB (100% inode=99%):
99=/=4280MB;9823;9833;0;9843 /boot=54MB;126;136;0;146
/fx_work0=325MB;19667;19677;0;19687 /dev/shm=0MB;908;918;0;928
27=0
51=1
115=1
25=1
76=10
58=1178921034
_____
Drexter
Sent: Wednesday, June 06, 2007 12:20 PM
Subject: [Nagios-devel] ndoutils1.4b3 issue with writing to mysql dbase
I am having issue with ndoutils 1.4b3 writing to mysql dbase. I receive a
"Broke pipe" error when running log2ndo or file2sock. Once the error is
generated the ndo2db is killed.
I am using ndo.sock for my unix domain socket. The perms on the socket are
srwxr-xr-x 1 apache apache 0 Jun 6 10:46
/opt/ACSnagios/var/ndo.sock
I have changed the perms to 777 and get the same results.
Netstat -P tcp:
Address Type Vnode Conn Local Addr Remote Addr
60002af8560 stream-ord 60012ee1d40 00000000 /opt/ACSnagios/var/ndo.sock
I am running Nagios as apache because I am using fruity webinterface for
configuration. The Nagios part works great.
I startup the ndomod daemon:
apache 23128 1 0 10:46:35 ? 0:00 /opt/ACSnagios/bin/ndo2db
-c /opt/ACSnagios/etc/ndo3db.cfg
The ndo2db is actually ndo2db-3x renamed.
In the Nagios.log file you can see the data sink is connected:
[1181140722] Nagios 3.0a3 starting... (PID=18095)
[1181140722] LOG VERSION: 2.0
[1181140722] ndomod: NDOMOD 1.4b3 (04-10-2007) Copyright (c) 2005-2007 Ethan
Galstad ([email protected])
[1181140722] ndomod: Successfully connected to data sink. 0 queued items to
flush.
[1181140722] Event broker module '/opt/ACSnagios/bin/ndomod.o' initialized
successfully.
Some of the variables in ndo3db.cfg
ndo2db_user=apache
ndo2db_group=apache
db_host=localhost
db_name=Nagios
db_user=nagios
db_pass=xxxxx
Some of the variables in ndomod.cfg...I have tried output_type unixsocket
and output = /opt/ACSnagios-3.0a3/var/ndo.sock
instance_name=default
output_type=file
output=/opt/ACSnagios-3.0a3/var/ndo.dat
buffer_file=/opt/ACSnagios-3.0
...[email truncated]...
