------=_Part_57208_14672677.1168971893816
Content-Type: text/plain; charset=UTF-8; format=flowed
Content-Disposition: inline
as I've been playing with the new 1.4b1 of the ndo databroker I noticed that
the nagios_service_contacts and nagios_host_contacts are not properly
"updated".
When ndo2db is updating the nagios_host_contacts table he does :
INSERT INTO nagios_host_contacts SET instance_id='1', host_id='3',
contact_object_id='34' ON DUPLICATE KEY UPDATE instance_id='1', host_id='3',
contact_object_id='34';
and then
contact_object_id='41' ON DUPLICATE KEY UPDATE instance_id='1', host_id='3',
contact_object_id='41';
But the table structure states that only instance_id is a unique key
therefore nagios_host_contacts contains only the latest entry and not any
other host to contact information ...
So you need to change the nagios_host_contacts and nagios_service_contacts
tables by adding them as unique keys.
Sorry if this was already report ...
Seb.
Content-Type: text/html; charset=UTF-8
Hi,as I've been playing with the new 1.4b1 of the ndo databroker I noticed that the nagios_service_contacts and nagios_host_contacts are not properly "updated".When ndo2db is updating the nagios_host_contacts table he does :
INSERT INTO nagios_host_contacts SET instance_id='1', host_id='3', contact_object_id='34' ON DUPLICATE KEY UPDATE instance_id='1', host_id='3', contact_object_id='34';
and thenINSERT INTO nagios_host_contacts SET instance_id='1', host_id='3', contact_object_id='41' ON DUPLICATE KEY UPDATE instance_id='1', host_id='3', contact_object_id='41';
But the table structure states that only instance_id is a unique key therefore nagios_host_contacts contains only the latest entry and not any other host to contact information ...So you need to change the nagios_host_contacts and nagios_service_contacts tables by adding them as unique keys.
Sorry if this was already report ...Seb.
------=_Part_57208_14672677.1168971893816--
