Re: [Nagios-devel] PATCH: Fix (make it less likely to happen) race
Martin Knoblauch wrote:
> Hi,
> there is apparently a race in the stop/restart functionality of the
> nagios init script.
> When doing stop or restart, the "$NagiosRunFile" can disappear between
> the check for existence and the "head" command in the status_nagios
> function. As a result one gets a nasty usage message from "ps".
> Observed on RHEL4/x86_64 with Nagios 2.6 and 2.7. The following patch
> seems to scare away the problem. It does not fix the race, but the
> problem does no longer occur.
> For me the additional 2 sec delay in stop/restart is acceptable.
I rewrote the init script a bit to help ensure this doesn't happen. The
head command is run to get the pid before it can be deleted by a
restart, etc. Patches are now in CVS for the 2.x and 3(HEAD) branches.
Thanks for the note!
Ethan Galstad,
Nagios Developer
Email: [email protected]
