[Nagios-devel] Adding a WARNING state for hosts
Hi
Currently in Nagios, the status of a host can be UP, DOWN, or
UNREACHABLE. I think this would be a good idea to add a WARNING state.
Imagine a host equipped with more than one ethernet interface (or even
another type of interface, such as a high-speed interconnect which you
can ping), and only one of its interfaces is failing. How would you
report this situation with the host status ? The host still can be
accessed, so it is not DOWN or UNREACHABLE, but the failing interface
has to be reported to the admin.
I know it can be done with a ping service for each interface, but I
think that putting ping as a service is not the good way to do it: what
the check-host-alive command would consist in then ?
Laurent Chauvirey
Clusters HPC Linux IA-32/IA-64
Open Software R&D -- Bull SA
