[Nagios-devel] Fix for host dependency checks
--x+6KMIRAuhnl3hBn
Content-Disposition: inline
There is a timing problem in the host[*] dependency check logic: If host
B is configured to be dependent on host A being up and host A goes down,
the dependency will only fail if host A "incidentally" was checked
_prior_ to host B after going down. Hence, the host dependency logic
will sometimes work and sometimes not. I'd therefore suggest to
explicitly (re-)check host A during the dependency checking for host B,
as the attached patch does.
Holger
[*] A similar problem _can_ arise for service dependencies, but unlike
for host dependencies, Nagios can be configured in a way that this
problem won't show up:
http://sf.net/mailarchive/message.php?msg_id=14420901
PGP fingerprint: F1F0 9071 8084 A426 DD59 9839 59D3 F3A1 B8B5 D3DE
--x+6KMIRAuhnl3hBn
Content-Disposition: attachment; filename="hostdep-check.diff"
Index: checks.c
RCS file: /cvsroot/nagios/nagios/base/checks.c,v
retrieving revision 1.81
diff -u -r1.81 checks.c
--- checks.c 23 Dec 2005 19:31:35 -0000 1.81
+++ checks.c 30 Jan 2006 12:51:40 -0000
@@ -1579,6 +1579,7 @@
int check_host_dependencies(host *hst,int dependency_type){
hostdependency *temp_dependency;
host *temp_host;
+ int route_result;
#ifdef DEBUG0
printf("check_host_dependencies() start\n");
@@ -1596,14 +1597,17 @@
if(temp_host==NULL)
continue;
+ /* check the host we depend on */
+ route_result=verify_route_to_host(temp_host,CHECK_OPTION_FORCE_EXECUTION);
/* is the host we depend on in state that fails the dependency tests? */
- if(temp_host->current_state==HOST_UP && temp_dependency->fail_on_up==TRUE)
+ if(route_result==HOST_UP && temp_dependency->fail_on_up==TRUE)
return DEPENDENCIES_FAILED;
- if(temp_host->current_state==HOST_DOWN && temp_dependency->fail_on_down==TRUE)
+ if(route_result==HOST_DOWN && temp_dependency->fail_on_down==TRUE)
- if(temp_host->current_state==HOST_UNREACHABLE && temp_dependency->fail_on_unreachable==TRUE)
+ if(route_result==HOST_UNREACHABLE && temp_dependency->fail_on_unreachable==TRUE)
- if((temp_host->current_state==HOST_UP && temp_host->has_been_checked==FALSE) && temp_dependency->fail_on_pending==TRUE)
+ if((route_result==HOST_UP && temp_host->has_been_checked==FALSE) && temp_dependency->fail_on_pending==TRUE)
/* immediate dependencies ok at this point - check parent dependencies if necessary */
--x+6KMIRAuhnl3hBn--
