Re: [Nagios-devel] More performance optimizations for 3.2.0,
--------------010904090409070203050207
Content-Type: text/plain; charset="ISO-8859-1"; format=flowed
On 01/28/2010 03:49 AM, Ton Voon wrote:
> I'm wondering if there is a better way of doing this. Rather than each
> caller having to work out the next comment id value and making sure it
> is still unique, I think the next_comment_id should be manipulated
> within xrddefault.c instead. If you call add_new_comment with a
> comment_id of 0, it uses next_comment_id and ensures it gets incremented.
The right place to control the uniqueness of comment IDs is at the layer
where comments are abstracted, i.e., comments.c.
Xrddefault.c is the wrong place to do this because xrddefault.c is only
one of several possible comment storage layers. Furthermore, it is not
the only place where comments are added; there's also xsddefault.c.
The API exported by comments.c needs to represent and support the fact
that there are actually two different comment-creation cases -- adding a
comment with a known comment ID (i.e., read in from previous state), or
adding a newly created comment that needs to be assigned a comment ID.
The code in comments.c should do the assigning in that case and return
the new comment ID to the caller.
The API syntax for distinguishing these two cases could be as simple as
always passing in a pointer to the comment ID, where the value in said
pointer is 0 if comments.c should assign the next ID, or non-zero if it
is already assigned and should not be changed by the caller.
However, the disadvantage of that simple syntax is that it will allow
bugs to creep into the code, the most likely one being a situation in
which the caller forgets to initialize the comment_id value to 0 before
calling the comment add API, thus causing a comment to be created with a
previously used comment ID. To avoid this, either separate entry
point(s) should be provided for creating comments with predefined
comments ID, or there should be a flag in comments.c that the caller has
to be set which indicates whether the operation currently in progress is
reading in old state or generating new state; when the former is in
progress, the comment ID must always be specified, whereas when the
latter is in progress, it can never be.
This will get a little complicated, e.g., when generating flapping
comments dynamically when reading in retention.dat. You'd have code
that looks like:
set_reuse_comment_ids();
... code to read and parse retention.dat ...
if (... existing logic for determining flapping ...) {
set_new_comment_ids();
... create new comment about the flapping ...
... finish reading and parsing retention.dat ...
All of this is the "right" way to fix the brokenness in this code, but I
was trying to make my changes as minimal as possible to make it easier
to verify their correctness and therefore more likely that someone would
be able to review and commit them. Furthermore, the changes I've
described above are somewhat architectural in nature, and I don't feel
that I'm an experienced enough Nagios developer to be in a position to
make architectural changes. And finally, I do have a job I'm supposed
to be doing instead of hacking on Nagios :-), and I can't really justify
spending more time on the cleaner implementation described above.
> I guess on the initial load of retention.dat you have to validate that
> the next_comment_id is unique,
No, you don't, really. Retention.dat is not supposed to be edited by
the user. It should be safe to assume that when it was saved, the
comment IDs saved to it were unique. If someone does need to edit it
for some reason, then it is their responsibility to preserve the
uniqueness of comment IDs when doing so. Considering how large
retention.dat can get (ours is 27MB) and how expensive it is to read and
parse it, this is a reasonable optimization which decreases the time
taken to read and process the file.
> Can you extend the tests in t-tap/ to time the performance increase?
> So I'm thinking that the patch ne
...[email truncated]...
