This morning we changed one of our loadbalancer VIPs to only accept SSL3 RSA_WITH_RC4_128_MD5. Now my check_http check fails with:
CRITICAL - Cannot make SSL connection
31691:error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version:s23_clnt.c:583:
HTTP CRITICAL - Error on receive
Digging around a bit I found I had an out of date nagios plugins set (1.4.14) which doesn't have the --sni option. However after updating my test Nagios instance to the new plugin version I get the same error. I've tried using -I instead of -H and tried with and without the --sni option, always the same thing.
Connecting to the site without specifying -S returns OK.
Anyone run across this before? I can't imagine check_http completely doesn't support SSL3 as an encryption method.
My production Nagios server is 1.3G running on the VM appliance.
