--00032557467a5e66e904634d911d
Content-Type: text/plain; charset=ISO-8859-1
I am also using the command pipe to submit passive service checks via nsca
to a master nagios host which does notifications and runs event handlers.
I am also interested in knowing what is the alternative to the command pipe
referred-to by Daniel.
On Thu, Feb 19, 2009 at 1:51 AM, wrote:
> Could someone light me about how to use something else than command pipe to
> improve performance?
> On Tue, 17 Feb 2009 08:32:32 -0800, "D. Emmanuel Feinsmith"
> wrote:
> > Alessandro,
> Its inefficiency primarily arises when it needs to either
> > receive passive checks (through the command pipe bottleneck)
> > The key to nagios scalability and latency reduction is to educe the #
> > of fork/exec's to the smallest amount possible and keep away from the
> > command pipe as much as you can if you are passive-check heavy.
> > Daniel.
> Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco,
> CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the
> Enterprise
> -Strategies to boost innovation and cut costs with open source
> participation
> -Receive a $600 discount off the registration fee with the source code:
> SFAD
> http://p.sf.net/sfu/XcvMzF8H
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=ISO-8859-1
I am also using the command pipe to submit passive service checks via nsca =
to a master nagios host which does notifications and runs event handlers.&n=
bsp; I am also interested in knowing what is the alternative to the c=
ommand pipe referred-to by Daniel.
On Thu, Feb 19, 2009 at 1:51 AM, <yann.jouanin=
.[email protected]> wrote:
Could someone light me about how to use something else than command pipe to=
<daniel@danielemma=
nuelfeinsmith.com> wrote:
> Alessandro,
> The key to nagios scalability and latency =
> of fork/exec's to the smallest amount possible and keep away from =
the
> Daniel.
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, C=
A
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterpris=
e
-Strategies to boost innovation and cut costs with open source participatio=
n
-Receive a $600 discount off the registration fee with the source code: SFA=
D
http://p.sf.net/=
sfu/XcvMzF8H
[email protected]=
urceforge.net
<a href=3D"https://lists.sourceforge.
...[email truncated]...
