This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C7A85E.DE938CF4
Content-Type: text/plain
I am having issue with ndoutils 1.4b3 writing to mysql dbase. I
receive a "Broke pipe" error when running log2ndo or file2sock. Once
the error is generated the ndo2db is killed.
I am using ndo.sock for my unix domain socket. The perms on the socket
are :
srwxr-xr-x 1 apache apache 0 Jun 6 10:46
/opt/ACSnagios/var/ndo.sock
I have changed the perms to 777 and get the same results.
Netstat -P tcp:
Address Type Vnode Conn Local Addr Remote Addr
60002af8560 stream-ord 60012ee1d40 00000000 /opt/ACSnagios/var/ndo.sock
I am running Nagios as apache because I am using fruity webinterface for
configuration. The Nagios part works great.
I startup the ndomod daemon:
apache 23128 1 0 10:46:35 ? 0:00
/opt/ACSnagios/bin/ndo2db -c /opt/ACSnagios/etc/ndo3db.cfg
The ndo2db is actually ndo2db-3x renamed.
In the Nagios.log file you can see the data sink is connected:
[1181140722] Nagios 3.0a3 starting... (PID=18095)
[1181140722] LOG VERSION: 2.0
[1181140722] ndomod: NDOMOD 1.4b3 (04-10-2007) Copyright (c) 2005-2007
Ethan Galstad ([email protected])
[1181140722] ndomod: Successfully connected to data sink. 0 queued
items to flush.
[1181140722] Event broker module '/opt/ACSnagios/bin/ndomod.o'
initialized successfully.
Some of the variables in ndo3db.cfg
ndo2db_user=apache
ndo2db_group=apache
db_host=localhost
db_name=Nagios
db_user=nagios
db_pass=xxxxx
Some of the variables in ndomod.cfg...I have tried output_type
unixsocket and output = /opt/ACSnagios-3.0a3/var/ndo.sock
instance_name=default
output_type=file
output=/opt/ACSnagios-3.0a3/var/ndo.dat
buffer_file=/opt/ACSnagios-3.0a3/var/ndomod.tmp
Here is the output of the truss of the log2ndo -s
/opt/ACSnagios/var/log/ndo.dat.060042007 -d /opt/ACSnagios/var/ndo.sock
-i default -t unix
19222: open("/opt/ACSnagios/var/xaa", O_RDONLY) = 3
19222: fstat(3, 0xFFBFF6D0) = 0
19222: d=0x03D40000 i=262972 m=0100644 l=1 u=0 g=0
sz=6288849
19222: at = Jun 6 09:43:39 CDT 2007 [ 1181141019 ]
19222: mt = Jun 6 09:43:29 CDT 2007 [ 1181141009 ]
19222: ct = Jun 6 09:43:29 CDT 2007 [ 1181141009 ]
19222: bsz=8192 blks=12304 fs=ufs
19222: mmap(0x00000000, 6288849, PROT_READ, MAP_PRIVATE, 3, 0) =
0xFE800000
19222: so_socket(PF_UNIX, SOCK_STREAM, 0, "", SOV_DEFAULT) = 4
19222: connect(4, 0xFFBFF6F8, 29, SOV_DEFAULT) = 0
19222: AF_UNIX name = /opt/ACSnagios/var/ndo.sock
19222: time() = 1181142021
19222: write(4, " H E L L O\n P R O T O C".., 178) = 178
19222: write(4, " 1 0 0 :\n 7 2 =\n 9 9 9".., 14) = 14
.........snipet
19222: write(4, " 1 0 0 :\n 7 2 = 3 = 0\n".., 17) = 17
19222: write(4, " 1 0 0 :\n 7 2 = 4 = 1 1".., 33) Err#32 EPIPE
19222: Received signal #13, SIGPIPE [default]
Drex
Content-Type: text/html
st1\:*{behavior:url(#default#ieooui) }
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font
...[email truncated]...
