Re: [Nagios-devel] Feature Request
------=_Part_10373_22862966.1175609853051
Content-Disposition: inline
On 4/2/07, Thomas Guyot-Sionnest wrote:
> Oops. In a totally unrelated event I noticed that I should leave it on
> then
> the host has notifications disabled (The service will still page in that
> case). Very oddly that after weeks of using that I noticed right after
> posting
> the link to the mailing list :)
> The link should be:
> @cgi-bin@/status.cgi?host=all&hostprops=10&servicestatustypes=28&serviceprops=8202
Thanks for the link. I've tried it without any luck. If the notifications
are disabled, it doesn't show up on the list as we would expect. However, it
does show up in the list if it's currently failing in a non-notifications
period as per the notification_period argument. I checked over status.c and
don't see anything there to tell the code to look at the
notification_period.
I still suggest that this would be a valuable feature in Nagios.
-David
Content-Type: text/html; charset=ISO-8859-1
On 4/2/07, Thomas Guyot-Sionnest <[email protected]> wrote:
Oops. In a totally unrelated event I noticed that I should leave it on thenthe host has notifications disabled (The service will still page in thatcase). Very oddly that after weeks of using that I noticed right after posting
the link to the mailing list :)The link should be:@cgi-bin@/status.cgi?host=all&hostprops=10&servicestatustypes=28&serviceprops=8202Thanks for the link. I've tried it without any luck. If the notifications are disabled, it doesn't show up on the list as we would expect. However, it does show up in the list if it's currently failing in a non-notifications period as per the notification_period argument. I checked over
status.c and don't see anything there to tell the code to look at the notification_period.I still suggest that this would be a valuable feature in Nagios.-David
------=_Part_10373_22862966.1175609853051--
