Re: [Nagios-devel] error log messages
Patrick Felt wrote:
> I’ve got a couple of error log messages that I’m trying to figure out.
> #nagios suggested that I submit them here as they might be bugs. The
> first is a large number of orphaned processors. According to Google,
> this is caused by high box utilization, however the nagios box is quite
> idle so I’m not sure what is going on
> The second is a large number of “Warning: Check result queue contained
> results for service 'Memory Utilization' on host hostname', but the
> service could not be found! Perhaps you forgot to define the service in
> your config files?” the preflight shows no errors so I’m unsure of what
> is happening here either.
> Are these bugs or have I configured something wrong?
> pat
Are you running 3.0rc1? The second item sounds like a bug that was
fixed in the rc1 release.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
