Could your config change have involved removal of a service that happened to
be running at the time? I recently found this problem in 3.4.4 and can easily
reproduce it.
http://tracker.nagios.org/view.php?id=424
Jens Hektor wrote:
> Hi,
> in the meantime I realized, that it is not so easy.
> What happened was this:
> in our 5k hosts / 11k services installation of nagios the accesspoints
> get updated by a script that pulls data from a database and writes individual
> files for each AP.
> A colleague ran this script and forcing nagios to relaod nagios crashed.
> I was not able to start nagios in that configuration and unfortunately
> I could not take a core dump.
> I suspected a memory error at that point and rebooted the machine but
> the error persisted.
> Running a diff against the old config files showed the missing parent
> as only major difference. Correcting that manually in the file for that
> AP fixed my problem.
> Then I wrote the message to this list.
> My colleague later showed me that there were other APs that had
> missing parents so it became clear that it is not so simple to
> reproduce the error.
> At the moment I am stuck and I cannot tip the finger at the error, sorry.
> So I will try later today if I can force nagios into that error again,
> but as I think that nagios is pretty rocksolid I fear I am not able
> to reproduce this.
> So I will come back when I have found something and we can close this upto now.
> Sorry and best regards, Jens Hektor
> On 22.02.2013 02:59, Eric Stanley wrote:
>> Jens,
>> I just tried what you suggested to reproduce the issue, but it did not
>> crash on me. Could you send what you used to get it to crash?
>> Thanks,
>> Eric
>> On 2/17/13 10:27 PM, Jens Hektor wrote:
>>> I had nagios core 3.4.4 crashing on an empty "parents" line in a host config.
>>> Guess it should be easy to reproduce: simply add a line, where after the
>>> "parents" are just some space characters.
> Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics
> Download AppDynamics Lite for free today:
> http://p.sf.net/sfu/appdyn_d2d_feb
> Nagios-devel mailing list
> [email protected]
