--------------070106070308030801070206
Hash: SHA1
On 15/06/09 02:27 PM, Thomas Guyot-Sionnest wrote:
> A better way of doing this is to send a connect for the next ip in list
> every n miliseconds (where n is a small fraction of the timeout, you
> could for example take half of the timeout and divide it by the number
> of IP), use the first connected socket and clean up the rest.
Just for clarification I'm not necessarily saying that we should do it
this way, but that if we really want to try all IPs that's the way
(IMHO) it should be done.
The attached patch removes the useless loop. There's no real-world
testing besides the compilation/tests.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFKNqS16dZ+Kt5BchYRAvnQAJ9bB5WMc6X9VRsj6/Pb7t54T1k+UgCeIbc9
wfnCEeJR+pt7N5cEyA8N+ls=
=xpIe
-----END PGP SIGNATURE-----
name="netutils.patch"
Content-Disposition: inline;
filename="netutils.patch"
diff --git a/base/netutils.c b/base/netutils.c
index 09f9453..443bc91 100644
--- a/base/netutils.c
+++ b/base/netutils.c
@@ -31,7 +31,7 @@
/* connect to a TCP socket in nonblocking fashion */
int my_tcp_connect(char *host_name, int port, int *sd, int timeout){
struct addrinfo hints;
- struct addrinfo *r,*res;
+ struct addrinfo *res;
int result;
char *port_str=NULL;
int flags=0;
@@ -52,29 +52,19 @@ int my_tcp_connect(char *host_name, int port, int *sd, int timeout){
return ERROR;
- /* attempt to create a socket */
- r=res;
- while(r){
- *sd=socket(r->ai_family,SOCK_STREAM,r->ai_protocol);
- if(*sd0)
- break;
- close(*sd);
- r=r->ai_next;
+ /* create a socket */
+ *sd=socket(res->ai_family,SOCK_STREAM,res->ai_protocol);
+ if(*sdai_addr,r->ai_addrlen);
+ result=connect(*sd,res->ai_addr,res->ai_addrlen);
/* immediately successful connect */
if(result==0){
--------------070106070308030801070206--
