> > The result is platform specific. 352 is the lowest common denominator for
> > maximum pipe buffer size. Using larger values can cause data from
> > different plugins to be interleaved - and then none of the data would be
> > understood...
> On Solaris, you can safely bump this up, as it uses 5120-byte atomic reads
> and writes to named pipes, as opposed to Linux's 512-byte atomic
> operations on named pipes.
Any idea where this is set in kernel? would it be possible to change this
in kernel without changing glibc?
roy
