On 12/15/2009 06:08 PM, [email protected] wrote:
>> It's your ld-fu that's weak. Basically, you can treat an ar-archive
>> as an object file when liking them together. That way you can choose
>> which libraries to link statically and which to link dynamically.
> You are correct. I strengthend my ld-fu (or rather my collect2-fu)
> and came up with:
> /usr/libexec/gcc/i386-redhat-linux/4.1.2/collect2 --eh-frame-hdr -m
> elf_i386 --hash-style=gnu -dynamic-linker /lib/ld-linux.so.2 -o send_nsca
> send_nsca.o utils.o netutils.o -lnsl -lgcc /usr/lib/crt1.o /usr/lib/crti.o
> /usr/lib/gcc/i386-redhat-linux/4.1.2/crtbegin.o -L/usr/lib
> -L/usr/lib/gcc/i386-redhat-linux/4.1.2 --as-needed -lgcc_s --no-as-needed
> -lc -lgcc --as-needed -lgcc_s --no-as-needed
> /usr/lib/gcc/i386-redhat-linux/4.1.2/crtend.o /usr/lib/crtn.o
> /usr/lib/libmcrypt.a
Impressive, though I'd have preferred something like
gcc send_nsca.o /usr/lib/libmcrypt.a -s -o send_nsca
> This gives me a dynamic linked send_nsca with static linked libmcrypt.
> Sadly I didn't check the size of libmcrypt.a and the stripped send_nsca
> is still 170kb - little bit too much for me.
> Guess I have to keep looking for a solution...
strip send_nsca
and it should lose about 100K.
OP5 AB www.op5.se
on peace.
