Linux Process Monitoring - Tomcat
SavaSC
Post by SavaSC »
I'm monitoring services on SLES 10 SP3. I can monitor ntpd and cron without issue, but when I monitor tomcat NagiosXI reports Nok. I can check processes, memory, and many other functions on any one of my SLES hosts, but this tomcat check fails wherever I apply it.
If I run check services here are the returns:
ltc061l:/usr/local/nagios/libexec # ./check_services -p tomcat
tomcat: 1
ltc061l:/usr/local/nagios/libexec # ./check_services -p tomcat5
tomcat: 1
Here's my own check:
ltc061l:/usr/local/nagios/libexec # service tomcat5 status
Checking for Tomcat (/srv/www/tomcat5/base/) running
Here's what XI is reporting:
tomcat
Critical 7s 1/5 2011-04-07 11:12:51 *** tomcat: Nok ***
ntpd
Ok 12m 48s 1/5 2011-04-07 11:13:33 ntpd: 1
Here's what it's using to check(ntpd is identical):
check_nrpe
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
$ARG1$ = check_services
$ARG2$ = -a 'tomcat'
Any ideas why the check runs fine on the server but reports the service down to the console?
tonyyarusso
Re: Linux Process Monitoring - Tomcat
Post by tonyyarusso »
Permissions. Tomcat is not allowing nagios to read its PID file most likely. Set up your check_services to use and be allowed by sudo for the nagios user.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
SavaSC
Post by SavaSC »
ssh as root
ltc061l:/tmp/linux-nrpe-agent # su nagios
nagios@ltc061l:/tmp/linux-nrpe-agent> cd /usr/local/nagios/libexec/
nagios@ltc061l:/usr/local/nagios/libexec> ./check_services -p tomcat
tomcat: 1
Same result as root. Not to mention I can check other services such as cron and ntp.
SavaSC
Post by SavaSC »
What's really interesting is that sometimes it checks out ok.
tomcat
Ok 2m 20s 1/5 2011-04-07 13:54:17 tomcat: 1
But the next time it checks it will fail. Or if I perform a manual check it will fail.
tomcat
Critical 6s 1/5 2011-04-07 13:58:03 *** tomcat: Nok ***
tonyyarusso
So, I just installed Tomcat and set up that check on a CentOS 5 system, and it's working fine, so I'm afraid I have no idea what your issue might be.
Tony Yarusso
Technical Services
___
TIES
SavaSC
Post by SavaSC »
OK, we run SLES. Any luck testing on SLES or are you saying SLES isn't supported? It's the 2nd or 3rd largest distro of Linux.
tonyyarusso
Well, it's not supported in the sense that we aren't particularly familiar with it and don't really do testing on it normally, but I'll still take a run at it tomorrow and see if I can figure anything out for you.
Tony Yarusso
Technical Services
___
TIES
tonyyarusso
All right, it's not just you! Turns out SLES has different behavior for 'ps' than other distros, specifically when output is not directed to a tty. Edit the plugin on the SLES server, and change this line:
                amt=$(ps aax | egrep "$patern" | grep -v egrep | grep -v "$PROGNAME" | wc -l | sed 's| ||g')
to this:
                amt=$(ps aaxww | egrep "$patern" | grep -v egrep | grep -v "$PROGNAME" | wc -l | sed 's| ||g')
(The difference is adding 'ww' to the ps arguments.)
Tony Yarusso
Technical Services
___
TIES
SavaSC
Post by SavaSC »
That worked great Tony. Thanks for checking it out!
tonyyarusso
Glad to hear it! Let us know if you have any further issues.
Tony Yarusso
Technical Services
___
TIES
