To create a patch;
Get the latest source-code from the CVS (instruction on sourceforge.
Click 'cvs access' or something like that).
Delete all the CVS directories and .cvsignore files from it
cp -a nagios nagios.orig
rm -rf `find -type d -name CVS`
rm -rf `find -type f -name .cvsignore`
Edit the files in nagios, so that you have an untouched copy in
nagios.orig, which is identical to the one you're working on.
When you're done making changes it's time to create the patch.
cd to the 'nagios' directory (the root of the sources where you've made
modifications), and run the following command;
diff -urN ../nagios.orig/ . > ../nagios.diff
-urN means, basically
Output in unified diff format (for use with patch), scan recursively for
changes, and treat new files in new directory as empty files in old
directory (they will be created when applying the patch). Make sure you
specify YOUR directory as the second one, or patch will try to look for
../nagios.orig when being fed the .diff-file.
If the modified source doesn't build OK, you'll have to recreate it from
scratch and make sure it does.
So, in summary;
cd ~
cvs -d:pserver:[email protected]:/cvsroot/nagios \
login
cvs -z3 -d:pserver:[email protected]:/cvsroot/nagios\
co nagios
rm -rf `find nagios -type d -name CVS`
rm -rf `find nagios -type f -name .cvsignore`
cd nagios
cd ~/nagios
diff -urN ../nagios.orig . > ../nagios.diff
CVS can do some of this for you, but can sometimes include somewhat
unpredictable results. If you're feeling dary, you can do the checkout
steps above, make your changes and then do cvs diff -urN from the
nagios-directory. Make sure you do 'cvs update' first in that case, or
your fresh patch might break some new code that has just been committed
to the repository.
Lars Volker wrote:
> Hi,
> wouldn't it be nice if nagios respectively the status.cgi would be able
> to recognize, if two host- or servicenames are domain names, which means
> dot-separated (like blabla.foo.bar.org.uk) and then sort the list in an
> domain-aware kind of way?
> Example:
> current behaviour:
> a.x.org
> a.y.org
> b.x.org
> b.y.org
> desired behaviour
> a.x.org
> b.x.org
> a.y.org
> b.y.org
> I've written a few lines of code, implementing that feature, but i
> edited the source directly and have never worked with patching stuff. So
> if someone would like to explain, i'll provide a patch. Anyways the code
> is just about 9 lines long, simple hack only, but working. There also
> should be some kind of switch to toggle the behaviour.
> Thanks
> Lars
Mvh
Andreas Ericsson
OP5 AB
+46 (0)733 709032
[email protected]
